Technisat SDK question
Robz
Using SkyStar 2 PCI card.
The documentation file “TechniSat_SDK.chm” indicates “A DirectX source filter B2C2MPEG2Filter, is used to send the streams to the user application.”
Question:
1. Where is the B2C2MPEG2Filter ? I have searched everywhere and cannot find the B2C2MPEG2Filter ; not even in Sonic directory or listed as a function inside a dll or other dll type files.
I do not have Microsoft Visual C++; but I do have Borland C++ builder and Borland Delphi 4. Not much luck using C++ Builder. The SDK does not work without a significant rewrite, as Borland C++ Builder does not use the Microsoft MFC class. Would really like to convert the SDK into Borland Delphi. Any help is greatly appreciated. TIA.
  • 2 years later...
Ok enough. You don't have to publish it in every thread having to do with the skystar 2. One thread is enough. Only very very very very very (times 10) few people have use for this :biggrin:
