Robo Posted December 19, 2006 Posted December 19, 2006 DVBViewer 3.2.5 won't start!! help!!! When I run DVBViewer 3.2.5 it just won't do anything; nothing comes up??? When I run, the TechniSat PVR DVBViewer it works fine. I NEED to run the 3.2.5 version because I have a program that reads the Teletext off of it. Does anyone know why 3.2.5 won't start? And I mean won't even show anything on the screen. When I click on it to run it, I see an hourglass for a split second then nothing. Please please please help Quote
Robo Posted December 19, 2006 Author Posted December 19, 2006 (edited) Thought I'd add some more info. DVBViewer 3.2.5 works on another PC next to this one (installed 1 year ago) but it won't work on this PC. I even copied the entire directory from the one PC to the other (after I installed the program) and I get the same thing. When I click on the DVBViewer program, it just won't run. Does anyone have any idea why it won't run? No error, no message... nothing. Edited December 19, 2006 by Robo Quote
Guest Lars_MQ Posted December 19, 2006 Posted December 19, 2006 No support for old version. Please update to the latest version of DVBViewer Pro. Quote
Robo Posted December 19, 2006 Author Posted December 19, 2006 No support for old version. Please update to the latest version of DVBViewer Pro. Do you know where I can download the latest? Ver 3.2.6? paid for 3.2.5, will my same user and PW work with 3.2.6? Quote
Tjod Posted December 19, 2006 Posted December 19, 2006 Do you know where I can download the latest? http://www.DVBViewer.com/members/ Username and Password are thous from DVBViewer Pro paid for 3.2.5, will my same user and PW work with 3.2.6?You paid for DVBViewer Pro (not only one Version )The current Version is 3.5.0 or better 5.1.120 Beta first install 3.5.0 and than copy the files from the Beta .zip Quote
Robo Posted December 19, 2006 Author Posted December 19, 2006 I downloaded 3.5.0 and it worked!!!! Thanks guys! Quote
