zazzel Posted September 27, 2002 Posted September 27, 2002 Hi, do you think it's possible to add PAL progressive to DVBViewer any time soon? I know about the current licensing problems - but maybe you could look into it... I think it will soon be a standard feature on most DVD players, so why not implement it in DVBViewer? :-) (Guess I'll have to upgrade my CPU, though...) - zazzel Quote
strauch Posted October 8, 2002 Posted October 8, 2002 PAL progressiv ist something for a DVD player or something like that. A pc can only pogressiv you simply have to change your resolution to 720x576 and you have a pal resolution with a progressiv signal, but the signal is rgb progressive not pal . The problem is the deinterlacing, the tv signal is interlaced and have to deinterlace with a nice codec to look fine @ a progressive solution. if you can speak german i can give you a deeper look into the progressiv/interlace/deinterlace theme. greetings strauch Quote
