pastimer Posted December 25, 2006 Posted December 25, 2006 (edited) Hi, When streaming HD channels my server cant handle it. I think - comparing to progdvb - that a lot of resources are wasted in an attempt to play the content on the server. In progdvb i have the startup option '/NoGraph'. I would like to disable any overhead. Just stream the selected channel. Is this possible? I cant find it. The video server is not realy an alternative as it doesnt use the channel list as far as i can see. If it's not possible, i suggest the option is taken into the broadcast plugin. Eppo Edited December 25, 2006 by pastimer Quote
hdv Posted December 25, 2006 Posted December 25, 2006 Hello, you can load the Graph Selector Plugin from Member-Area, with that, its possible to take No Renderer for Video and Audio. Quote
pastimer Posted December 25, 2006 Author Posted December 25, 2006 Hello, you can load the Graph Selector Plugin from Member-Area, with that, its possible to take No Renderer for Video and Audio. Great! Thanks! Quote
Dr. Cain Posted December 31, 2006 Posted December 31, 2006 Either that or use DVBServer which hardly uses any resources at all. Quote
