hm67 Posted December 26, 2006 Posted December 26, 2006 It seems DVBViewer cannot access the CI module properly, I get a black screen on any pay channels. I tried both wdm and dba drivers and both the released and the current beta version, same problem. If I run the CI concole from twinhan in the background it seem to work for a while but suddenly for no apparent reason DVBViewer will just freeze the picture and then I cannot view anything without restarting it, maybe this is a separate problem fromt he first. If I run twinhans program it all works fine so it´s not an issue with my hardware. I have read about other people having the same issue with DVBViewer and pay channels but no real solution, is this a known problem with DVBViewer ? Please, how can I get the pay channels to work, it´s pretty useless otherwise. Quote
Engelbert Posted December 26, 2006 Posted December 26, 2006 Do not use the NERO decoders and for audio use both the AC3Filter. And use the DVBfilter V 2.8.2 Register it! Quote
hm67 Posted December 26, 2006 Author Posted December 26, 2006 (edited) Not sure why the mpeg encoders would matter when this seem to be a descrambling problem but I have tried various settings for mpeg decoder as well without much success. Edited December 26, 2006 by hm67 Quote
Engelbert Posted December 26, 2006 Posted December 26, 2006 There are no encoded transmitters on DVB-T in Germany. Which model no. has your card, which BDA driver, which CAM: where do you live? Right transponder list? Quote
hm67 Posted December 26, 2006 Author Posted December 26, 2006 (edited) This is tiresome, you dont read properly, like I said, works perfectly with Twinhans DTV app so this in your app, why do you have a cam menu if it doesnt work ? I want a refund. Edited December 26, 2006 by hm67 Quote
Engelbert Posted December 26, 2006 Posted December 26, 2006 Without information about your system it is not to help you. Quote
Klaus_1250 Posted December 26, 2006 Posted December 26, 2006 (edited) Without information about your system it is not to help you. From another thread: Sweden, Boxer network, Twinhan 3040, Viaccess CAM. Edited December 26, 2006 by Klaus_1250 Quote
