am1969 Posted December 26, 2006 Posted December 26, 2006 I am having trouble updating channels. When I use the channel scan DVBViewer doesn't seem to update with any new channels found when the application is launched. Quote
Klaus_1250 Posted December 26, 2006 Posted December 26, 2006 (edited) I take it you scanned with TransEdit? If so; After scanning, did you select the new channels (lines with a completely white background) and clicked "Send to DVBViewer"? Also, did you select channels with changed properties (lines with white boxes in them) and clicked "Update"? Edited December 26, 2006 by Klaus_1250 Quote
am1969 Posted December 26, 2006 Author Posted December 26, 2006 I take it you scanned with TransEdit? If so; After scanning, did you select the new channels (lines with a completely white background) and clicked "Send to DVBViewer"? Also, did you select channels with changed properties (lines with white boxes in them) and clicked "Update"? Thanks! I'll give it a try Quote
