linusalba Posted April 16, 2003 Posted April 16, 2003 http://www.ircatanzaro.com/gene/ Hi, i see that DVBViewer Channel Navigator i still on ver.0.5.21, is there any new version coming soon? How can i have a trasparent nemu? Now i have a black blackground menu and i'd like a trasparent one. Bye and thanks for this little program, Marco Quote
Klausing Posted April 16, 2003 Posted April 16, 2003 You must set the background in the ini to the overlay color. You get this color if you make a screenshot of your viewer, put it (for instance in Paint shop pro) in a graficprogramm and measure the RGB Color of the main window. Quote
linusalba Posted April 17, 2003 Author Posted April 17, 2003 You must set the background ....put it (for instance in Paint shop pro) in a graficprogramm and measure the RGB Color of the main window. great! Thanks a lot, Marco Quote
