Kiez82 Posted December 29, 2006 Posted December 29, 2006 Hi! I'm about to install Windows Vista, but does DVBViewer work with Vista? Does anyone have any experience about that? -Kiez- Quote
Kiez82 Posted February 7, 2007 Author Posted February 7, 2007 Hi! I'm about to install Windows Vista, but does DVBViewer work with Vista? Does anyone have any experience about that? -Kiez- Nobody doesn't know?? Quote
Tjod Posted February 7, 2007 Posted February 7, 2007 I did not have experience. DVBViewer Pro works with Vista. But many driver and other problems a still present. Use the Forums Search with Vista. I will try Vista if i have time because i got it for free (MSDN-AA). But i will use it not for daily work, until at least servicepack 1 is out. First time i installed Windows XP was after servicepack 2 was out, that bewared me from many problems. Quote
Benarty Posted February 7, 2007 Posted February 7, 2007 I did not have experience.DVBViewer Pro works with Vista. But many driver and other problems a still present. Use the Forums Search with Vista. I will try Vista if i have time because i got it for free (MSDN-AA). But i will use it not for daily work, until at least servicepack 1 is out. First time i installed Windows XP was after servicepack 2 was out, that bewared me from many problems. Stick with XP, Vista is too new. Micorsoft was never able to release a stable OS in the first place. So why would they do it this time better? Drivers are always a problem with a new released OS. And beware of Vista, if it detects a flaw in a driver, poof, driver gone. Quote
Benarty Posted February 9, 2007 Posted February 9, 2007 yes it does works Sure DVBViewer works on Vista but the problems are DRIVER related. Quote
