hackbart Posted December 29, 2006 Posted December 29, 2006 Today we released the new DVBViewer version which comes with the following changes (compared to the last beta): Version 3.6.0.0--------------- [*]Add: Added recordingservice. [*]Fix: EPG-Window: Fixed "&" was replaced by "_" in Timeline. [*]Add: Recorderwindow: Added play running recording to contextmenu. [*]Add: Recorderwindow: Added doubleclick on running recording switches to the channel the timer is recording. [*]Fix: COM-Events: Fixed several glitches. [*]Fix: Siehfern: Fixed endless loop in receiving due to too small buffers. [*]Add: Channels/EPG: Added selection for EPG-Source in chaneleditor. The source: - DVB EPG: EIT, ATSC and Premiere Portal EPG. - Internal EPG: SiehFernInfo, MHW(+) - External EPG (for EPG-Importers) Default is: allow all sources. [*]Change: OSD: When changing to subpages the selection in the EPG and channelwindows now is remembered. [*]Fix: OSD: fixed pagecounter of lists. [*]Fix: CAM: Fixed missing first entry in MMI menu on some CAMs. General improvement of CAM/CI support. [*]Fix: EIT-EPG: Fixed loosing of entries in Kabel1/Pro7/Sat1 austria. [*]Fix: Vista support: Fixed several issues with vista. [*]Change: Signaldisplay: changed signal display for some pinnacle and terratec devices. [*]Fix: Vista support: Fixed several issues with vista. [*]Change: Added a splitter to some windows so the Headerpanel can be hidden by mouse. [*]Change: OSD-Properties: added some properties regarding picture handling of epg entries. [*]Fix: Radiomode: fixed a bug when starting viewer in radio mode. [*]Change: Signaldisplay: changed signal display for some pinnacle and terratec devices. [*]Update: Language: updated several language files. [*]Change: Signaldisplay: changed signal display for some pinnacle and terratec devices. Christian
