deniax Posted December 31, 2006 Posted December 31, 2006 (edited) Hi, When I record a h264 stream to a .ts file and set the program to split it at, for example, 100mb, the program freezes. Also, the second file is not created. When I select the same stream to output the data to mpg and split at 100mb, it works as a charm and at 100mb, the next file is created. I've attached the support.zip to this message support.zip Edited December 31, 2006 by deniax Quote
