legjno Posted January 1, 2007 Posted January 1, 2007 Hi, Is there anything specific to consider before update from version 3.5 to 3.6, or can I just start setup.exe and all my settings remain as before the upgrade ? I can't find anything in the manual or in the forum regarding upgrades. legjno Quote
Gioxy Posted January 1, 2007 Posted January 1, 2007 Don't worry, your existing settings are preserved during the upgrade (anyway a copy/backup of all .xls files in the DVBViewer dir, where your setting are stored, isn't a bad idea...) The only item to take care of is the Channel List: simply uncheck it during installation if you don't want overwrite it... Quote
