azitroc Posted January 5, 2007 Posted January 5, 2007 I'm playng around this Net streaming without being able to sort out the problem. I have a PC with SS2 as a server, with DVBViewer installed, and I have a Laptop PC that I would like to use as a client. I would like to be able to change channel from the client and from server alternatively. I try many configuration, I use unicast but not working, with multicast I can watch TV on client but I cannot change the channel. Anyway it is not stable, everytime I open both programs I have to pray that everything is working fine that time. Actually I am using plugin Netstream on server PC and Mulicast on hardware options on the laptop. Is there any different configuration can allow me to have a stable connection and change program from client? Thanks for the help, bye Quote
hdv Posted January 5, 2007 Posted January 5, 2007 Hello, the best is, you use DVBServer and a DVBViewer as Client. Here is a How to, but only in german Unicaststreaming DVBServer --> DVBViewer PS: and you must have the same channellist on Server/Client, so copy the channel.dat from installation folder to the client. Its no Beta matters so moved. Quote
Mikko-vaari Posted January 11, 2007 Posted January 11, 2007 Hello, Here is a How to, but only in german Its no Beta matters so moved. Yes, but it is already half a year old and the photos are not from the latest version. So, at least I am little confused how to get the streaming working properly. At present I can't get any confirmation of the client to the server. And when the server has been started the Dvb script:emoticon('', 'smid_25') Quote
