Mouse Wheel No Function
Antonis
Hello,
just a minor annoyance:
Is it possible to add a "Do nothing" in the list of the supported functions for the mouse wheel (Options, Input, Mouse)
Or make it possible to deselect all checkboxes. I use 2 monitors with DVBViewer windowed on the 2nd and i find myself accidentaly use the wheel when DVBViewer has focus.
Right now i have volume up/down but since i always keep dvbviewers volume to 100% (use other vol control) i frequently find volume going down to 0% while trying to scrolling on the first monitor
Can you please please give an option to disable the mouse wheel?
Thanks,
Antonis
Hello,
not a Option, but a Workaround. ;)
Open the file setup.xml with an editor like notepad and search the section "Mouse"
  </section>
 <section name="Mouse">
<entry name="Action">4</entry>
<entry name="Doubleclick">0</entry>
 </section>
The Action 4 is Volume Control, if you change
into
<entry name="Action">-1</entry>
you have no function with the mouse wheel.
But you must edit the correct setup.xml please look here for more informations about the Usermode.
:bye:
Thank you
It worked!!
It is possible to have it added to the user interface as well?
Since its a simple case of writing "-1" to the settings file
Thanks again for the fast reply
Antonis
