Bathman Posted January 8, 2007 Posted January 8, 2007 I am sure this is dead obvius. But I would like to delete the number of TV stations recieved in my channel list from how do I do it. I cant get anywhere when following the online manual. Quote
Gioxy Posted January 8, 2007 Posted January 8, 2007 I would like to delete the number of TV stations recieved in my channel list ...if you whould hide it (why delete it? ) you can simply right click on the channel list and click on "Show channel number"... Quote
Bathman Posted January 8, 2007 Author Posted January 8, 2007 I dont think I made my self clear. (english not first language) 9 When I have DVB watching,. When I go to time line I have hundreds on channels eg bbc1 anglia, bbc 1 central, bbc1 meridian. I want to set DVBViewer to show me just one bbc Channel (BBC yorks). Therefore I want to delete all the others. I tried to set numerous channels to favorites and this has helped but unfortuatly I have set some channels to favorites which are not favorites and now I cant delete them from favorites. Is there any way to delete channels from favorites. Tamur, tamur, khoob, khoob abar Quote
Gioxy Posted January 8, 2007 Posted January 8, 2007 Click on: • menu "Channel" • item "Channel editor" • button "Edit Fav." • select the channel you wanto to delete • press the middle bottom button (it show a little recycle bin) to delete • remember to save the edited favourite list with the next button (the little floppy disk) Quote
Bathman Posted January 9, 2007 Author Posted January 9, 2007 Many thanks for your reply - but there is a problem. When I tick on "Channel Editor" nothing happens (apart from a tick appearing next to it) there isn't any "Edit Favorites" to edit. • menu "Channel" • item "Channel editor" • button "Edit Fav." • select the channel you wanto to delete • press the middle bottom button (it show a little recycle bin) to delete • remember to save the edited favourite list with the next button (the little floppy disk) Quote
Gioxy Posted January 9, 2007 Posted January 9, 2007 Ah, I think I got the point... • close DVBViewer and go in the prog folder (normally C:\Programs\DVBViewer) • open the file file setup.xml with Notepad (or similar plain text editor) • search for "frmChannellist" • edit the value of this two line, setting "0" in both <entry name="X">0</entry> <entry name="Y">0</entry> save, start DVBViewer and enjoy... Quote
Bathman Posted January 9, 2007 Author Posted January 9, 2007 Again many thanks for you reply. I have tried this but still no luck - any other suggestion • close DVBViewer and go in the prog folder (normally C:\Programs\DVBViewer) • open the file file setup.xml with Notepad (or similar plain text editor) • search for "frmChannellist" • edit the value of this two line, setting "0" in both <entry name="X">0</entry> <entry name="Y">0</entry> save, start DVBViewer and enjoy... Quote
Gioxy Posted January 9, 2007 Posted January 9, 2007 (edited) mmmh, a can't guess anymore... Try to follow these instructions... Edited January 9, 2007 by Gioxy Quote
Bathman Posted January 9, 2007 Author Posted January 9, 2007 Hmm, The plot thickens. I have installed an old version (3.2.6) and I am able to delete and amend my channel listings. But when I install the latest version I am not able. I'll play around a bit more and if I dont get anywhere then I'll submit a bug report. Quote
Gioxy Posted January 11, 2007 Posted January 11, 2007 ...it seems that a solution is to write down the entire missing "frmChannellist" section from an old installation... I think you can place it everywere in the Setup.xml, but originally it is right before the "frmAbout" section... This is an example of how it could look: <section name="frmChannellist"> <entry name="X">100</entry> <entry name="Y">100</entry> <entry name="W">300</entry> <entry name="H">600</entry> <entry name="Headerheight">49</entry> </section> Quote
Bathman Posted January 13, 2007 Author Posted January 13, 2007 Problem solved see http://www.DVBViewer.com/forum/index.php?showtopic=16340 Quote
Gioxy Posted January 13, 2007 Posted January 13, 2007 your setup.xml is write protected or you look into the wrong file?which of the two? Quote
fuhrer Posted September 10, 2022 Posted September 10, 2022 hello : i know i'm too late, sorry , but i can't find the " setup.xml " file! please somebody help me , thanks Quote
Griga Posted September 10, 2022 Posted September 10, 2022 In DVBViewer click on Help -> Configuration Folder. It opens an Explorer window. There you can find setup.xml. Close DVBViewer before changing this file! Quote
