Andrew Posted January 8, 2007 Posted January 8, 2007 Hi. I´m quite happy with my mce-remote, butt not with the mce (windows media centre edition). Does anybody know how to disable the greenbutton in a simple way. Quote
esackbauer Posted January 9, 2007 Posted January 9, 2007 You must prevent ehtray.exe from running. Either kill it with Windows Task Manager, or delete it from registry at HKLM/Software/Microsoft/Windows/CurrentVersion/Run Quote
Andrew Posted January 10, 2007 Author Posted January 10, 2007 You must prevent ehtray.exe from running.Either kill it with Windows Task Manager, or delete it from registry at HKLM/Software/Microsoft/Windows/CurrentVersion/Run Does that kill the entire remote or just the ”greenbutton”. If not thanks a' lot Quote
