pjc Posted January 11, 2007 Posted January 11, 2007 Hi, I just installed DVBViewer this morning. I haven't had chance to take a good look at the features, so I may be missing something. Does DVBViewer support logical channel numbering? If not, is there a way to change the numbers manually, so it doesn't start from zero? Thanks. Quote
Gioxy Posted January 11, 2007 Posted January 11, 2007 I'm not rock sure, but if I remember correctly the number of the channel is determined by the channel scan... and, obviously, it can change at every new channel scan... but: If you refer to "Favourite number 0" there is a simple dirt&quick solution: insert the first channel two time... Instead (or furthermore), if you want to renumber all channels you can use a little tool you can download from the last line of the last post of this italian tread: Cambiare il numero associato ai canali? (thanks to dioveht)... Quote
pjc Posted January 11, 2007 Author Posted January 11, 2007 Thanks Gioxy. That download is just the type of thing I was looking for. Quote
