jusubbi Posted January 13, 2007 Posted January 13, 2007 (edited) If i left DVBViewer running recording something it goes to standby when recording is over. Ok, this working fine, but the problem is when i resume from standby, then DVBViewer is jammed on but doeing nothing. With older version i don't have this problem. With older version DVBViewer was closed when resume from standby. see picture below and attachments. support.zip Edited January 13, 2007 by jusubbi Quote
Dvb-tv Posted January 14, 2007 Posted January 14, 2007 This is true for me and is a known symptom i see, after it a while it does return. As when i come back to the pc i can see it has returned. The duration you have to wait i do not know, i have not tested that. I am happy to report all your schedules should be recorded beutifully, and that is the importance. If you find out how long the duration is, can you write back here and tell us. Then again jusubbi it maybe something we have both got set wrong or is DVBViewer. Maybe someone will let us know here if DVBViewer or not. Quote
