Dvb-tv Posted January 14, 2007 Posted January 14, 2007 I'm sure i had turned the instant recording button off again. Blinking looks like i didn't do that just that. I got a whole day of one channel recorded. I did not want that channel recorded. I needed the programs i had scheduled to be recorded. After spoiling a whole days scheduled recordings because of the Instant recording. Of which some scheduled episodes will takes some years to repeat again. Thats if they don't go to pay-per-view instead grrr. Please can you make this instant recording an options setting, so can be adjusted manualy. Each user can then change from the now 24hrs instant record. To a user set time duration, for me 5-10mins is more than enough. Quote
Guest Oliver Posted January 14, 2007 Posted January 14, 2007 Please can you make this instant recording an options setting, so can be adjusted manualy. Each user can then change from the now 24hrs instant record. To a user set time duration, for me 5-10mins is more than enough. You can preset the duration in the options dialogue. Quote
Dvb-tv Posted January 14, 2007 Author Posted January 14, 2007 (edited) Ah thank you Oliver i totaly missed that one, it is default set at 1,439m. I will change that to 5m for 5mins, 5m i did not understand at first. I can confirm that the new instant record setting of 5m does record for 5mins only. Can the instant record button be changed for it to turn red when instant recording is active only. Oposite colour green or blue or similar for not active. Edited January 14, 2007 by Dvb-tv Quote
