channels.dat - not used anymore?
AndersB
Where are the channels stored for DVBViewer? My channels.dat does not contain the channels. I even renamed channels.dat to be sure and restarted DVBViewer - channels still there. Went in to channel editor, deleted the channellist, saved it and restarted DVBViewer - channels are there again.
Guest Lars_MQ
Open help -> Info -> Versionsinfo there you can see where the userdata is stored (just click the link there).
Great thanks!
Found it under c:\documents and settings\all users\application data\cmuv\DVBViewer
