Serban Posted January 18, 2007 Posted January 18, 2007 Can the forum help? I have purchased the software in the hope that would work with my Digital Terrestrial hardware, but it seems that the hardware is not recognized. When I start the DVB Pro the message on the screen is that the hardware is not found. I have a Twinhan USB VisionPlus receiver which is correctly installed and recognized in the system properties as USB-DVB-T adapter and the manufacturer appears as "USBDTT Technology". The label of the device indicate: "TwinHan Technology Co. Ltd., Model Vision DTV USB Ter Model 7041." It appears that the software is compatible to the TwinHan Terrestrial Receivers. Can somebody help with this issue? Quote
Guest Lars_MQ Posted January 18, 2007 Posted January 18, 2007 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
Tjod Posted January 18, 2007 Posted January 18, 2007 Did you make a channel scan? The Channellist in the DVBViewer Installation is only for Sat. Quote
