fesche Posted April 24, 2003 Posted April 24, 2003 Salut ! Now a bit more complicated request: I have a R/C which has too less keys for all necessary funktions. Can you make some Keys (or all) be double-selectable? e.g. while i am in normal viewing mode, the four cursor keys shall change volume and program, but in OSD mode I want to move there with the same keys. Is this possible ? I would be even happy with a new setting (selectable option) if keys must be unique or not. I would care about double settings to work properly together. Quote
Guest hackbart Posted April 26, 2003 Posted April 26, 2003 currently there are a few keys double selected: 1. Channel Up & Channel Down -> if OSD is active, they are used for up and down 2. Last Channel -> if OSD is active, it is used as one level up 3. OSD Enter: if OSD is not visible, it is opened by pushing the button 4. Keys 0-9 are also used for teletext, if the teletext window is opened Christian Quote
fesche Posted April 28, 2003 Author Posted April 28, 2003 Salut ! okay, this is what I found out myeself, too. but theese are fixed double-selections. Can I double select some keys by my own ? curently I need to use my VCR remote controller to get all functions working because it hast more keys than my remote controller what I would like to use. But it is not really handy. Quote
