a19a Posted January 19, 2007 Posted January 19, 2007 Hi, I am trying to use DVBViewer Service for my scheduled recordings but I have a problem. When I create a scheduled recording (and I choose the option use VideoRecorder) the resulting file it is written in the standard recording folder, and NOT in the folder choosen in the VideoRecorder plugin settings. Another problem is that using DVBViewer Service with VideoRecorder, it won't record the additional pids that I choose in the VideoRecorder plugin. help me please, a19a Quote
Tjod Posted January 19, 2007 Posted January 19, 2007 The DVBViewer Service did not use any plugins. You could change the recording folder Record Settings...>(the arrow behind Description)>Recording Folder. Options>Recorder you could chose the things which shout recorded. Quote
a19a Posted January 19, 2007 Author Posted January 19, 2007 You could change the recording folder Record Settings...>(the arrow behind Description)>Recording Folder. which arrow? I configured the recording folder of course...I thought that DVBViewer Service could use the Videorecorder's folder. I think that this becomes a feature request: I need to specifiy which pids to record from a channel from recording options. Now it's not possible. thanks, a19a Quote
a19a Posted January 19, 2007 Author Posted January 19, 2007 This here clicking the arrow the folder option is not selectable. I use the new DVBViewer. a19a Quote
Tjod Posted January 19, 2007 Posted January 19, 2007 OK you have to add Folder first via Options>Recorder. Then select to each recording in which folder it will be saved. Quote
