Guest DAvenger Posted April 26, 2003 Posted April 26, 2003 Hiho Kekso is working on a new Media Library software and needs some good ideas which would guide him through the functionality jungle Click here to see the original post (you will need to register) This software might be eventually used in future versions of DVBViewer ... as a module Thanks in advance for any help Quote
fesche Posted April 28, 2003 Posted April 28, 2003 Salut ! as i do not want to register EVERYWHERE I post my reply here. Using WMP9 from our big boss Bill, I am getting used to some smart functions like: If you start a Song or CD, WMP automatically searches its internal AND external databases for suiting information not only full Title and CD cover, but also for a critics to the album, some discographic infos about the interprete and some more. newer CDs are well detailed. One Thing what I would like to ave more easy to modify is some of the ID3 Tags. I like sorting my music by "Genre" So usually I have to modify every track or file. a nice function is to change all selected files at once. And do not forget a well detailed IR remote control unit !!!!!! Quote
Kekso Posted April 29, 2003 Posted April 29, 2003 Hi! Sure. Do not worry about the best way how to fill IDTags of your media files. Everyithing shold be done automaticaly or manualy by using some king of script and macros. Be creative... Quote
