cmet Posted January 24, 2007 Posted January 24, 2007 This really seems like a great program. I only have one problem in that the EPG will not load and the EPG icons are shaded Everything else seems to work fine. I have reinstalled many times, using the newest drivers i could find. I have read and searched the forums and the manual. I Do not think the problem is in the card or the drivers as I can get guide info with the TSReader program. The EPG is not disabled in the setup menu I am probably overlooking the obvious answer, so feel free to scold (as long as you point me in the right direction) Win98SE AMD Athlonxp 3000+ 512KB location USA Thanks in advance for your assistance Walter support.zip Quote
jerryt Posted January 26, 2007 Posted January 26, 2007 (edited) This really seems like a great program. I only have one problem in that the EPG will not load and the EPG icons are shaded Everything else seems to work fine. I have reinstalled many times, using the newest drivers i could find. I have read and searched the forums and the manual. I Do not think the problem is in the card or the drivers as I can get guide info with the TSReader program. The EPG is not disabled in the setup menu I am probably overlooking the obvious answer, so feel free to scold (as long as you point me in the right direction) Win98SE AMD Athlonxp 3000+ 512KB location USA Thanks in advance for your assistance Walter No EPG data available, with Airstar, FusionHDTV and Twinhan, ATSC cards. It used to work? Don't know when it Quit. Any suggestions for settings which may be wrong? Thanks Edit; FusionHDTV and Twinhan players have EPG data so I know the data is available. Edited January 26, 2007 by jerryt Quote
