Disable audio/video?
Travis Bell
Hey guys, I know that when you schedule a recording you easily enough disable the A/V but what about when DVBViewer is just open?
Sometimes, I'd like it to just sit there open (and tuned) while I am doing other CPU intensive related tasks and would like to disable the video until I am done.
I know MyTheatre does this and I was hoping DVBViewer could to.
I have tried that "Close graph" button but had issues re-tuning to a channel without restarting.
Thanks guys, I think that is my last question...
Hello,
use Channel -> Last Channel, to rebuilöd the closed Graph, or you switch to another channel.
Guest Lars_MQ
Try disable AV on minimize in the options, use disable AV in the main menu or you can define in the input options on a custom command which disables A or V or A/V. Close graph does a complete closing and can interupt recordings (or timeshift).
Yeah, that's what I am trying to avoid.
Ok, I will give these all a try! Thanks!!
I might just be blind but I don't see anything to do with "disable AV" in the options OR main menu... only time I see it mentioned is in regard to recording settings.
Thanks!
Maybe the DVBViewer is the workaround champion ;) You are not the 1st who asked for a button which seems to be a standard feature in many other tv-applications. I'll bet you'll get a couple of proposals to solve your problem. No, not with a single button though you might learn to program one ;)
I stopped asking and use a quite old method which doesn't conflict with ongoing recordings. It consists of the old graph selector plugin and a simple null_graph. That works quite well. Only one little problem. When switching back to the normal graph, the volume will be 100% :)
Guest Lars_MQ
Options _> TV & Radio -> DisableAV on minimize
And the stuff with the main menu, sorry, I thought it was in there :)
Look in "Settings / Options / TV + Radio / Disable AV on minimize"... there you are...
I see the null graph here... I'll give it a shot.
Thanks man.
Edited by Travis Bell
