Skystar HD - diseq1.2 positioner
dk1
I have recently got Skystar HD, diseq 1.2 motor with USALS.
It is amazing that DVBViewer works with Motor ! Watching HDTV channels also works fine although some consume around 80% CPU time. I think I have well invested 15Euro for this excellent programm
My question is that, when I try to tune program from another Satelite than current one, there is no motor driving progress and I have to retune the channel again in a few seconds, after I am sure dish has moved to correct position.
IS there something like diseq1.2 (USALS) driving progress or can I define wait time before channel is actually tuned when moving between satellites ?
Maybe also some settings how many times to repeat diseq command?
thanks
Edited by dk1
Had much the same problem with my TT S2-3200 (which I think the Skystar HD is a clone of). Try setting "retune on missing stream" in Options|Hardware to around 5 secs and it should work quite well. A lower value will save waiting time when the dish gets to the sat but be aware that currently the retune cycle times out after 10 retunes - I believe this limit is to be removed in the next update of DVBViewer.
See this thread for more insight into the problem.
hth
