pastimer Posted January 28, 2007 Posted January 28, 2007 Is CI supported for the TT s2-3200 card in Ex? I can't find a list of cardfeatures to look this up.. Regards, Eppo Quote
Griga Posted January 29, 2007 Posted January 29, 2007 CI is supportet by BDA-drivers. That's definitely wrong. CI support is not part of the BDA specifications. However, DVBViewer supports the TT 3200 CI by using a TechnoTrend DLL, that provides a vendor-specific interface. @pastimer: Please post in the English section of the forum, if you want to write in English!!! Quote
Engelbert Posted January 29, 2007 Posted January 29, 2007 (edited) OK, but not without BDA-drivers at DVBViewer. Original name: ttBdaDrvApi.dll. Edited January 29, 2007 by Engelbert Quote
pastimer Posted January 31, 2007 Author Posted January 31, 2007 OK, but not without BDA-drivers at DVBViewer.Original name: ttBdaDrvApi.dll. Thanks so far. Where can i find this DLL? Is it with the driver? Do i have to install TT Media Centre? Where do i place it? Eppo Quote
hackbart Posted January 31, 2007 Posted January 31, 2007 The latest TT API DLL (Version 1, 0, 0, 5) is part of the current DVBViewer. I just renamed it to ttAPI.dll in order to avoid complications with older versions of this dll. If you have the latest DVBViewer it should work without any problems - verified with Alphacrypt and Conax, and Viaccess modules. Christian Quote
mitsu Posted January 31, 2007 Posted January 31, 2007 (edited) If you have the latest DVBViewer it should work without any problems - verified with Alphacrypt and Conax, and Viaccess modules. Not exactly without problems. Sometimes changing to crypted channel you need to rebuild graph. Sometimes decrypting refuses to work completely and a reboot is needed (or maybe restarting S2-3200 and DVBViewer would be enough). I haven't found the logic yet but it may happen only after resuming from hibernation. I have a devcon script to restart S2-3200 after resume prior to starting DVBViewer. Edit: I'm using Conax for Canal Digital channels from Thor 0.8W Edited January 31, 2007 by mitsu Quote
