Is it possible to run 3.6 in taskbar
bakerpr
Is there a setting so allow DVBViewer to run in the background/taskbar to allow recordings to proceed without having to leave the program open.
hum, if the prog is running it means the prog is also "open"... did you mean "iconized" in the taskbar?
Anyhow, the last DVBViewer Pro ver. introduce a new service, "DVBViewer Recording Service", that need to be updated to ver. 1.0.5 to work at is best... Find it in the beta section of the Member section...
Edited by Gioxy
Thanks I'll give that a go.
I must be missing something because I set a recording and closed dvdviewer which set the recorder active however the service stayed idle in the taskbar past the record time.
When I relaunched DVBViewer started the recording all be it slightly late.
...it could be a little tricky, consider it is still in beta test...
You can ask for more in the proper tread, but, please, read it before...
