Helio Posted January 30, 2007 Posted January 30, 2007 Hi, Is it possible to have the channels in timeline as you have in favourits? If it is plaese point out where to look. Regards Helio Quote
hdv Posted January 30, 2007 Posted January 30, 2007 Hello, you mean the OSD-Timeline? Then OSD-Timeline -> OSD-Blue -> Show Favorites. In EPG Window -> Timeline, use the Filter at bottom edge. Quote
Helio Posted January 30, 2007 Author Posted January 30, 2007 Hello, you mean the OSD-Timeline? Then OSD-Timeline -> OSD-Blue -> Show Favorites. In EPG Window -> Timeline, use the Filter at bottom edge. Thanks , The problem still. In EPG Window works 100% but not in OSD-Timeline Show All or Show Favorites no diference . The same order . Quote
Gioxy Posted January 31, 2007 Posted January 31, 2007 Uhm, the channels visualized are correctly limited to the favourites, as the choice state... But yes, you're right, the order remain... unordered IMO they simply appear in the same order they were downloaded... Quote
Helio Posted January 31, 2007 Author Posted January 31, 2007 Uhm, the channels visualized are correctly limited to the favourites, as the choice state... But yes, you're right, the order remain... unordered IMO they simply appear in the same order they were downloaded... Thans Quote
