Loss of video and sound after 3 seconds - newbie question
Paul I
Hi all,
Just purchased and installed the software...looks good, but have hit a snag.
Hardware detected OK, terrestrial channel scan OK (better on GE than PRO), lots of audio and video channels detected, 100% signal on most, BUT...I'm only getting about 3 or 4 seconds of audio or video before either the video freezes and the sound cuts out.
The application is still responsive, and I can swap channels, see the EPG info etc etc....just can't get any picture or sounds until restarting the application.
I downloaded the GE as well as PRO, and the same problem occurs. I also downloaded TransEdit and tried the preview feature on that, and get the same problem. Is this indicative of a CODEC related issue?
I'm using a Freecom DVB-T stick (old chip set I think, judging by the lack of letters on the serial number), with the Freecom BDA drivers.
Any help would be appreciated...
Cheers,
Paul.
Just a brief update to this....after further playing I've noticed that if I change to a channel on a different broadcast frequency (is that a multiplex???) I get 3 - 4 seconds of video and audio before the picture freezes and sound halts.
So if I start on BBC1, I get 3 - 4 seconds before the picture to freezes, and sound stops, then switch to BBC4, I get a 3 - 4 seconds of BBC4 before the picture freezes and the sound stops, and then if I switch back to BBC1, I can repeat the process...
However if I repeat the experiment swtiching between BBC1 and BBC2, which broadcast on the same frequency I get no picture or sound after the first 3 - 4 seconds on BBC1.
Is this a de-multiplexing issue perhaps?
Cheers,
Paul.
had the same problem , try changing your video decoder
Hey - thanks for the help. So you have any suggestions on what to use?
I've tried three now and all demonstrate the same issue:
Elecard MPEG-2 Video Decoder
Intervideo Video Decoder
Cyberlink Video/SP Decoder (PDVD7)
Rather frustrating!
Cheers,
Paul.
I've expanded the list now to include:
Intervideo Video Decoder (v8)
GPL MPEG 1/2 Decoder
ffdshow MPEG4 decoder
All without success.
I've also tried some Windows MCE drivers another board suggested, bundled with the WideViewer DVB-T WT-220U as apparently they have the same chipset - but these appear to be worse...
Any thoughts anyone?
P.
Check what the property page of the DVBViewer Filter (View -> Filters -> DVBSource) reports. It contains the demultiplexer.
