kikkoman Posted February 2, 2007 Posted February 2, 2007 When I try to watch DVB-S2 H.264 channels, the picture lags every few seconds. When I checked the cpu usage core 1 was allmost 100% and everytime it topped 100% the picture froze for a second or two, Core 2 was on 1-10% the whole time. Is it possible to activate dual core support for CoreAVC? I'm using newest DVBViewer Pro, Core AVC H264 Decoder 1.2 and my computer is a E6700, 2gb ram and a x1650pro. If dual core support is impossible on CoreAVC what decoder do you recommend that supports it? Here's a picture of the cpu usage. Quote
kikkoman Posted February 2, 2007 Author Posted February 2, 2007 I solved it. Had the option only use first cpu checked in. Now everything works great. Quote
sluisga Posted February 3, 2007 Posted February 3, 2007 what other codecs and video renderers are you using in your direct X section? DVBViewer keeps crashing when I try and view one of these channels. Quote
kikkoman Posted February 4, 2007 Author Posted February 4, 2007 what other codecs and video renderers are you using in your direct X section? DVBViewer keeps crashing when I try and view one of these channels. I used Powerdvd but it has stopped working now somehow, thinking of ordering CoreAVC. Quote
sluisga Posted February 4, 2007 Posted February 4, 2007 I used Powerdvd but it has stopped working now somehow, thinking of ordering CoreAVC. I've got the CoreAVC codec but when I use it, DVBViewer crashes and I get an avcdx.ax error. I've managed to get it working on ProgDVB EE but in DVBViewer, the video displays as big boxes. Quote
