ocho Posted February 3, 2007 Posted February 3, 2007 Whats the best way to get more epg information? at presents i am on Astra 19.2 and a lot of the epg is in German How do i use mediahighway and fern? which channels do i go to what is the setting tab for this used for in options? which Internet sites can i use to download more epg data at present the only sat channel i use is guide tv Quote
ianred22 Posted February 3, 2007 Posted February 3, 2007 I use XMLTV GUI which I use against the Radio Times website. It can access other European sites Then use MYXMLT which is a vailable from the download section to map this against channels within DVBViewer. Generally seems to work really well. I have BBC mapped to Film4 at the moment which I am trying to work out. Quote
ocho Posted February 3, 2007 Author Posted February 3, 2007 Can not get XMLTV to download anything, says that it is writing XML but nothing in the data file can you help Quote
ianred22 Posted February 3, 2007 Posted February 3, 2007 Click on the grabber you want for instance UK_RT Then select the channels button. Then select the channel you want and move to the seleected channel list Quote
