Diseqc 1.2 rotor support with S2-3200 and BDA drivers?
Knowbody
Hi! :)
I'd decide to buy DVBViewer if it supports Diseqc 1.2 (moving the dish) with my S2-3200; rotor is a Stab HH120. The rotor works fine with e.g. ProgDVB and the WDM drivers, but as DVBViewer only supports the S2-3200 using the BDA drivers(?), I wonder if it could move the dish via the BDA drivers as I've read that BDA doesn't support Diseqc 1.2 which means DVBViewer would have to use some proprietary function to send Diseqc 1.2 commands.
Can you confirm DVBViewer can send Diseqc 1.2 commands to my S2-3200 using the BDA drivers? If so, I'll buy DVBViewer immediately.
Thanks in advance! :jump:
