Diodato Posted February 4, 2007 Posted February 4, 2007 Hi all, The EPG window (timeline mode) has fixed width columns. Maybe for the time intervals fixed width is desired, but the first column is also fixed width. In the first column channel names are also in bold so practically channel names differ up to 8 characters, the rest are truncated and the standard "..." added. Could this column have width user selectable set? Quote
Tjod Posted February 4, 2007 Posted February 4, 2007 It is possible to change it. You have to edit the setup.xml you will find the wright one About>Info..>Versionsinfo and click on the blue link than the folder with the right setup.xml will open. Close the DVBViewer, open the setup.xml with Notepad. <section name="Timeline">...... ....... <entry name="LeadingWidth">140</entry> and change this. Quote
