fulcrium Posted February 4, 2007 Posted February 4, 2007 after I arranged the channel list, it's always returned to the general situation after restart the program!!!! with the default list. how i can solve this problem?? I hope you understand my problem, because I cant speak english well! Quote
Engelbert Posted February 5, 2007 Posted February 5, 2007 Your problem seems nobody here having understood. It needs more information there what it is about? Quote
Gioxy Posted February 5, 2007 Posted February 5, 2007 I arranged the channel list How you did this? Or maybe you refer to "favourite list"? Quote
fulcrium Posted February 6, 2007 Author Posted February 6, 2007 If I opened the program for the first time, the channel list is appeared like the first image in the attachments. Than, I arranged the channel list as same as it appeared in the second image in the attachments. After that, if I close the program, always after restarting it, it will returned to the first situation like its appeared in the first image!!! I mean it appeared like I didn't do anything with the channel list before! The channel list never saved by the program. Quote
Gioxy Posted February 6, 2007 Posted February 6, 2007 This can happen if DVBViewer crash at exit... Try to modify the channellist as you wish and (before tuning any channel) close DVBViewer; then wait at least 1 minute before restart it... And, of course, think about upgrade to Pro version: it is plenty worth the 15€ it cost... Quote
fulcrium Posted February 6, 2007 Author Posted February 6, 2007 Try to modify the channellist as you wish and (before tuning any channel) close DVBViewer; then wait at least 1 minute before restart it... I did that but no advanced!! I thing i'm going to update Quote
Tjod Posted February 6, 2007 Posted February 6, 2007 I think your problem is that the DVBViewer is not able to wright the channels.dat You could try to move the channels.dat to a other directory may be than the DVBViewer is able to create a new one. If you run DVBViewer Pro in a no admin account you should not run it in Compatible mod (usermode.ini UserMode=0). Quote
