Switch to a defined channel on exit
Liquidator87
How can I tell DVBViewer to automatically switch to a channel before turning off?
If you want to start DVBViewer with a specific channel you can simply add a parameter:
-c = DVBViewer shows no channel at first (standby)
-cNumber: = Switches to the given channel number.
Example: c:\ program files\DVBViewer\DVBViewer.exe -c12
-cName: = Switches to the channel with the given name.
Example: c:\ program files\DVBViewer\DVBViewer.exe -cMTV Central
:bye:
what would be the use of such thing?
If you watch a porn channel and forget to switch to a "normal" program before closing the DVBViewer the wife will be surprised when opening the dvbv for watching her soap show :bye::D
I'm sorry but I need to switch to a channel before exit.
Guest Lars_MQ
this is not possible, you could construct of course something a batchfile or a script around the DVBViewer otherwise it's only on startup.
And since you won't give any explanations there is nothing which shows a real need to integrate such thing.
I'm sorry, I wanted to do this because I noticed that DVBViewer crash when I close it from some channels, but not from some others.
This causes me problems when I've a timed record which turn off the computer at the end; if DVBViewer crash, it won't turn off the computer.
Have you tried turning on "Settings / Options / Disable LNB on completion"?
Yes, and also "Disable error messages"... no way
  • 1 month later...
:bye:
Good, it work's
Edited by ficofico
