trouble with daemontool
tage
Hi
do i have to use secure mode to get the mount to work? if i have it enable 2
windows open when open a file to mount and i have to press "ok" on both..
if i uncheck secure mode and open a file to mount DVBViewer says "disk insert do you want to play"
and i press ok but the screen jump to a channel again and no movie starts..
if i check daemontool no image is mounted..
daemontool setup :
device 0: [F:]
DVBViewer setup:
virtual drive F:
drive nummer 0
/ Tage
