mjugogo Posted February 9, 2007 Posted February 9, 2007 Hi, I just purchased DVBViewer 3.6 Pro. During the installation, I entered my username and password and it installed well. But the first time I opened it, it asks me again for username and password. When I enter those, and click OK, DVBViewer closes instantly. Every I open it, it happens. Did I misunderstood something or should I contact technical support ? Thanks Quote
hdv Posted February 9, 2007 Posted February 9, 2007 Hello, please take a look in the registry HKEY_LOCAL_MACHINE\SOFTWARE\CM&V\DVBViewer and check the correct password (capital and small initial letters are important). Its not help, please write a mail at this adress click. Quote
mjugogo Posted February 9, 2007 Author Posted February 9, 2007 Values in the registry seem to be correct. I'll write to the adress you gave. Thanks Quote
improve Posted April 14, 2007 Posted April 14, 2007 (edited) I have the same problem (v3.6.1.20). The registry is ok. Can any help ???? Tested version 3.2.6 and works fine, but I want that newest version work so great!!! Edited April 14, 2007 by improve Quote
chris1p Posted April 14, 2007 Posted April 14, 2007 Hi Any solution to this problem yet? I have just loaded DVBViewer Pro 3.6.1.20 and have the same issues. I checked the registry, its OK. Any ideas? CP Quote
improve Posted April 15, 2007 Posted April 15, 2007 Found solution: in usermode.ini change the mode to =0 and replay config of program. For me works fine. Quote
