Recording Service and Vista.
inkogn
Does recording service work on windows vista? I have technisat airstar 2 and DVBViewer Pro. Viewer seems to work fine, but service doesnt seem to start. I already tried compatible modes.
Guest Lars_MQ
You did activate use recordingservice in the DVBViewer -> plugins menu? An the trayicon app is running (that's where you see if it runs, otherwise you have to look into the services applet in windows settings stuff).
Yes i did. Trayicon keeps being gray no matter what i do.
edit: Complete reinstall did the trick.. Thanks anyway.
Edited by inkogn
No it does not. :idiot: .. Trayicon now changes to color as recording but nothing appears to hard disk. And no dvbservice running at task list.
Guest Lars_MQ
is there a svcdebug.log file? if yes please zip it and post it here.
Here.
I dont know if this is the right one. I installed Vista today.
edit: uploaded the right one.. :idiot:
svcdebug.zip
Edited by inkogn
Guest Lars_MQ
11.02.2007 11:26:07 Allocate Hardware AirStar 2 PCI
11.02.2007 11:26:07 VCR-Internal Found fitting Hardware: AirStar 2 PCI
11.02.2007 11:26:07 DoRecord Finding EPG
11.02.2007 11:26:07 DoRecord Eläimelliset veljekset
11.02.2007 11:26:07 TDVBHardware.SetTuner PMT: 258SID: 65
11.02.2007 11:26:08 StartRecording: Nelonen
11.02.2007 11:26:08 VCR-Internal Recording did start.
11.02.2007 11:35:00 Release Hardware AirStar 2 PCI
11.02.2007 11:35:00 Destroy Hardware AirStar 2 PCI
I don't see any problem, it seem to work as exspected. Could you explain a little more why you think it does not work?
Hmm.. I tried again and now recording seems to appear to video-folder. But tray icon says tha service is on idle. :idiot:
I have changed DVBVservice.exe to XP Compatibility mode, if that has something to do with this change.
Edited by inkogn
