Shamrocks Posted February 12, 2007 Posted February 12, 2007 Hi, everyone. I think DVBViewer is a brilliant htpc-applikation. I use 2 FireDTV dvb-c tuners and its working perfect! Before I started using DVBViewer I used MCE2005 with the FireDTV BDA-plugin. But MCE2005 lacks a lot of features that is to be found in DVBViewer. Only thing I really miss in DVBViewer is the ability to load the EPG with XMLTV-data, because the EPG is almost useless for scheduling recordings when I only have EPG-listings for few hours worth. I have found an old beta-tool that supposedly could import XMLTV-data into the DVBViewer EPG, but it doesnt seem to work. I found a post that said something about that its caused by some changes made in the latest version, which im running. I would say that if it was made possible to import XMLTV-data into the DVBViewer EPG then it would be just PERFECT!! So my question is, is it just because i havent found the right import-tool, or is it a feature that will be supported in the future?? (I really need to be able to schedule recordings throughout the week...) Configuration; DVBViewer v3.6.0.2 2*FireDTV dvb-c on Viaccess P4 3 Ghz 2 Gb ram Kind Regards, Shamrocks HTPC w. 2*FireDTV dvb-c / Viaccess 2.0 Quote
HJCR Posted March 31, 2007 Posted March 31, 2007 Hi I installed the myXMLTV program today. It seems to work but I found the following that seems important: For your needs you have to look into "Settings // Options... // EPG/Teletext" and: check Do Not Receive EPG Data (otherwise the DVB-EPG will overwrite your imported XMLTV data!) check Receive MediaHigway EPG Data check Persistent EPG Data set Compression level to 0 or 1 It seems to work for me but I need to do some more checking to be sure. Still I have to figure out how to automate the process. Quote
