Windows Vista Aero fullscreen bug
Maketee
DVBViewer 3.6.1.0, Windows Vista Ultimate 32bit, NVidia 8800GTS, Forceware 100.59.
Using Windows Aero. When I use DVBViewer in fullscreen mode (F), it leaves taskbar visible. It also leaves right side of DVBViewers window visible. If I manually hide taskbar, it also shows bottom of DVBViewers window. Screenshot
If I disable Aero, then it works ok.
Same problem here with Version 3.6.1.2 and an ATI x1600 Graphic Card.
Franz
DVBViewer 3.6.1.2 using an ATI Express 200 M integrated grafic is fine as long as you are not using the "No Skin" skin. Vista aero remains enabled for the OS.
Edited by Apfelmaus
same bug
using: x1950pro 256mb | pentium m 2.0ghz | 1024mb ram | VISTA business premium <- big bug ^^ but neccessary :bye:
have the same problem
using: Nvidia 7600GT; Dualcore 2,4GHz; Asus mainboard P5LD2; 1GB ram; WV Ultimate
Edited by Ivunin
Something like this....
Home Premium, 64 bits
DVBViewer: latest
Option->DirectX->Video Renderer :
Unchanged: Aero enabled, Black Screen
Overlay Mixer: Aero disabled, picture ok
VM9+VM7 Video Mixing Renderer: Aero enabled, picture small (in full screen picture is small)
I have the same problem - the screen looks just as shown above.
No problem with Vista for me:
- Select WMV9 as render if you want to keep Aero (Vista doesn't support anymore Overlay)
To solve Fullscreen bug:
- Right click on DVBViewer -> Properties -> Compatibility -> Check the "DPI" checkbox (sorry, I have the Italian version)
