Get videotext from an AirStar2 card
Romme
I have problem getting the Videotext functions to work on my AirStar2 card.
I have both a SkyStar2 and an AirStar2 card in the computer. And the videotext works fine
in the DVBViewer app. on both cards.
But from the COM object I can only get Videotext info from channels on the SkyStar2 card.
There are no problems with getting ex. EPG informations from the AirStar2 via the COM.
Is there a general problem with this ?
/Romme
Guest Lars_MQ
No. ttx is handled all the same for all devices, nothing which could explain the behaviour you experience.
COM Interface and TTx- Window in DVBViewer use the same data.
Any idea why this happens?
Can I run some sort of debugging that can show what the problem is?
/Allan
