Slow channel change and x1600 or 6200
Kris
Hi
my spec
AXP M 2Ghz
1gb Ram
Win Xp Home.
this is dedicated HTPC machine
the channel change is really really slow.... (some times frezz even )
do the codec have something to do with this ?
is better to use Ati x1600 128Mb or GF 6200 128Mb
Pure Video will probably give a bust with GF 6200 ?
now im using standart dscaler codecs
sorry for Poor English.
PS I LOVE DVBViewer.... :bye:
Hi
my spec
AXP M 2Ghz
1gb Ram
Win Xp Home.
What is AXP? AMD Athlon XP-M2000?
It's clocked on 1,67Ghz then
It has 512KB L2 cache....not HDTV capable
What is slow?
FTA channels zap fastest, depending on used DVB card between 0,2 and 1 second.
encrypted channels add 2 max 4 second, zo fast zap is not possible.
Codec: PowerDVD7 codec runs fine
Use AC3audio decoder
The Geforce6200 supports only limited purevideo functions.
Note: type is not enough, which X1600? standard, GT or Pro
Do not change videocard untill channel change problem is fixed.
Edited by Benarty
What is slow?
XPM = Athlon XP Mobile it is 2500+
now it is Overclocked to 2.4Ghz...
Yes FTA it take 5 seconds.. or more...
Shappire X1600 Pro.
Thx :bye:
Guest Lars_MQ
don't, try better codecs.
I will thx :bye:
is better to use BDA drivers from Twinan or WDM ?
