valrond Posted February 17, 2007 Posted February 17, 2007 I have recently purchased the pro version of DVBViewer, and have been using it under Xp 32 bit flawlessly. However, when I try it under Vista 64 bit, the image of DVB-T it's unstable, there isn't a constant flow of the source image, while in XP 32 bit works perfectly. I use the same video and audio codec on both (nvidia for video, and powerdvd for audio). And the thing is that Windows Media Center under Vista x64 works almost perfect, much better then DVBViewer. Besides, when using DVBViewer, Vista reverts to basic colors and if I run the task manager it gives an error code and quits. Quote
