ritsmer Posted February 18, 2007 Posted February 18, 2007 I have 3.6.1.2 (paid version) and when I record by pressing the record-button it records to the folder I have entered (on my E-disk) - but when I record via EPG and the PVR all recordings are done to C:\Documents and Settings\All Users\Shared Documents\Shared Video - how do I change this?? Quote
Guest Lars_MQ Posted February 18, 2007 Posted February 18, 2007 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
ritsmer Posted February 18, 2007 Author Posted February 18, 2007 Please post some more information:http://www.DVBViewer.info/forum/index.php?showtopic=2210 Sorry. Hope this is sufficient? setup.xml support.zip Quote
Guest Lars_MQ Posted February 18, 2007 Posted February 18, 2007 It seems you haven't defined any recording folders? there are no differences between an instant timer and a normal timer. they use the same folders. Quote
ritsmer Posted February 19, 2007 Author Posted February 19, 2007 It seems you haven't defined any recording folders? there are no differences between an instant timer and a normal timer. they use the same folders. Thank you very much for helping in this. As I really had defined a recording folder and as the recording was made into this folder when pressing the red recording button - but in another folder when recording via the EPG send to PVR - I uninstalled the DVBViewer etc., deleted the Program Files and reinstalled it. By the first install I had selecetd "for all users" but this time I selected for one user. Then I booted - just to be sure. Now the recordings with the red button and the PVR revordings both goes into the right folder - BUT the recordings are made double - that is: into two files??? Please see the attached files. Sorry for bothering with this - but I really do not know how to correct it, so that I get only 1 recording. support.zip Quote
