Channel Scan and DisEsc settings problem
GuruM
I cant seem to fig out my LNB Connections for my 4/1 Disec Switch
I need help in connecting each time after scan I get No data on two of my sattelites
Here are my connections on my dearmbox
LNB 1 >AA > nothing
LNB 2 > AB > Hotbird 13 east
LNB 3 > BA > Astra 2 28E
LNB 4 > BB > Astra 1 19E
I am trying to config the same for my DVBViewer but I do get signal and scan show many channels but afetr a scan when I go to channel it says No data. Just LNB 4 Astra 1 19 East is working while same setup works great on dreambox
Also same settings work great in Pinacle Media Centre
Can Anyone just write a detailed Diseq settings for me .
I am using Pinnacle HDTV Sat Pro USB device
Many thanks
Edited by GuruM
Get TransEdit from the menbers area and use it for scanning. In TransEdit it's more obvious what is happening.
You may use the Preview function to check if the channels are working and export the result to the DVBViewer channellist (Send Button).
In case of further questions refer to the TransEdit manual.
Thank you for quick response I will give it a try
