Start DVBviewer in OSD mode?
Satfreakje
is it possible to show the OSD-menu immediately after starting DVBViewer ?
Currently it shows TV first and when pressing ESC it takes me to the OSD menu.
I tried searching for this in the forum but maybe it wasn't asked for or perhaps it was asked/explained in German, a language i don't master.
Cheers,
Geert
Hello,
yes its possible, use a commandline for this.
like this "D:\Programme\DVBViewer Pro 3.6\DVBViewer.exe" -x8201
The example start the DVBViewer and shows after starting the OSD-Timeline.
Take a look in the actions.ini, which you find in installationfolder of DVBViewer Pro.
After any action you see a number which you can use as commandline, and with -x it called the number.
PS: the number 111 shows the OSD Menü like you press ESC
:bye:
Hi hdv,
that's great news, many thanks!
Is this documented somewhere? Maybe there are other options which might be of use to me?
Geert
EDIT : forget about my question, found the answer in the forum.
Edited by Satfreakje
Hello,
Are there other switches also?
Why not combine them in a text so that everyone can read it: avoids some questions also.
