patti Posted February 23, 2007 Posted February 23, 2007 Hi! Is it possible to use DVBViewer to record several encrypted channels simultaneously from one MUX using one Conax cable card? This works for non encrypted channels but I don't seem to get it to work when the first recorded channel is encrypted. DVBViewer does not tune into other encrypted channels from that MUX. Thanks Quote
Guest Lars_MQ Posted February 23, 2007 Posted February 23, 2007 No, just one encrypted channel per card/CI. Quote
patti Posted February 24, 2007 Author Posted February 24, 2007 No, just one encrypted channel per card/CI. Is this built-in in Conax system or is it in DVBViewer? Thanks again Quote
Guest Lars_MQ Posted February 24, 2007 Posted February 24, 2007 The limit is the CAM/Driver combo, some can only record one, some can record an unknown number more, so the DVBViewer uses the least common factor. Quote
bestbox Posted February 24, 2007 Posted February 24, 2007 (edited) Is it possible to get an "open" beta-version for testing what is possible in a specific system? Edited February 24, 2007 by bestbox Quote
patti Posted April 5, 2008 Author Posted April 5, 2008 (edited) No, just one encrypted channel per card/CI. Hi, I'm getting back to this question as something seems to have changed here. Earlier it was like Lars_MQ said and DVBViewer jumped over other encrypted channels when recording one. Now it is possible to start a recording on an encrypted channel (conax) and then switch to another encrypted channel on the same MUX. The downside of this is that the recording stops when you switch to another channel. This is a problem when using timer recording as you don't necessarily know that you're recording and then switch to an encrypted channel and your recording stops but you don't notice it. So, the question is, how to prevent this from happening? Is there an option to prevent switching to another encrypted channel when recording one or what is going on? I first noticed this behavior last spring if I remember correctly, so it is not a new feature that came along with the latest version. I have two Twinhan Mantis CAB-CI cards with one Digiality Conax CAS5 CAM. Thanks in advance patti Edited April 5, 2008 by patti Quote
patti Posted April 5, 2008 Author Posted April 5, 2008 Here is a small thing that I noticed when looking at the problem more closely. The encrypted channels that I have are all on the same mux these days while a while back they were on two different muxes. So I am not sure if that was what made DVBViewer to skip other encrypted channels but now I have 7 encrypted channels and all of them are on the same mux and it causes problems. THis info is for clarification on the backgrounds but the problem still exists. Quote
Derrick Posted April 5, 2008 Posted April 5, 2008 Nothing has changed. but now I have 7 encrypted channels and all of them are on the same mux and it causes problems ..I don't understand. If you have problems cos the muxes have changed, you'll have to check with your provider. Quote
patti Posted April 5, 2008 Author Posted April 5, 2008 (edited) Nothing has changed. ..I don't understand. If you have problems cos the muxes have changed, you'll have to check with your provider. Maybe I wasn't being clear. I don't have problems with the muxes themselves or with the provider. What I meant to say was that earlier as the channels were on different muxes the conax card and tuner were tied to that mux when recording was on. So it was impossible to change channel to another encrypted channel on another mux. Now that all the channels are on the same mux it is possible to start a recording on one encrypted channel and then accidentally or on purpose switch to another encrypted channel which causes the recording to freeze because the card is now tied to encrypting the new channel. DVBViewer allows this channel change, how can I prevent it? Doesn't anybody else have this problem? patti Edited April 5, 2008 by patti Quote
Derrick Posted April 5, 2008 Posted April 5, 2008 it is possible to start a recording on one encrypted channel and then accidentally or on purpose switch to another encrypted channel which causes the recording to freeze because the card is now tied to encrypting the new channel. DVBViewer allows this channel change That should not be possible. ..please attach a support.zip Quote
patti Posted April 5, 2008 Author Posted April 5, 2008 Check out my previous post a few messages above... Quote
Derrick Posted April 6, 2008 Posted April 6, 2008 I have two Twinhan Mantis CAB-CI cards with one Digiality Conax CAS5 CAM. hmm, I've overlooked that you have 2 cards. Uncheck "Has CI module" for the card without CI-module. Quote
patti Posted April 6, 2008 Author Posted April 6, 2008 hmm, I've overlooked that you have 2 cards. Uncheck "Has CI module" for the card without CI-module. It is and has been unchecked but the problem remains. I also tried "open whole transponder" and "new tuning method" and "send only encrypted channels to CI" but they didn't help either. patti Quote
Derrick Posted April 6, 2008 Posted April 6, 2008 The tuning mode is not relevant for your problem. Same with "send only encrypted channels to CI". This option shouldn't be used. Assign an exclusive group to the crypted channels and the card with ci-module. Quote
patti Posted April 6, 2008 Author Posted April 6, 2008 The tuning mode is not relevant for your problem. Same with "send only encrypted channels to CI". This option shouldn't be used. Assign an exclusive group to the crypted channels and the card with ci-module. I already have channel group A for FTA channels and group C for encrypted channels. Tuner 1 with the CI has groups A and C and tuner 2 has only group A. Tuner 2 is set to mode "preferred" and tuner 1 is "normal". The problem is not helped by this. patti Quote
patti Posted April 6, 2008 Author Posted April 6, 2008 OK, I have some info regarding this problem. I installed older versions of DVBViewer and checked to see whether they have the same problem. Version 3.6.1.20 was the last version that I have that doesn't have this problem. 3.8.0.0 and newer versions are affected by the problem. Hope this helps. patti Quote
Derrick Posted April 6, 2008 Posted April 6, 2008 Dunno, maybe a bug? Handling multiple devices with ci capability seems to cause problems. I can't help, I only have a single ci_card.. Quote
patti Posted April 6, 2008 Author Posted April 6, 2008 OK, I'll file this to bug reports with the findings that I have made. Thanks for your effort patti Quote
