DVBViewer Problem - Line on TV Image
dragonuk
Hello
Ok, I'll try to explain the problem.
I have a Freecom DVB-T USB2.0 TV TUNER, and any TV channel that I am watching has a horizontal line about 1/3 of the way up from the bottom. And under this line, the image is all fuzzy and pixelized. Anything above this line is all clear.
Its not a monitor problem, as the line is there regardless of when the window is on the screen. And it doesnt happen when watching dvds etc with media player.
Any ideas on how I could fix it? Or anyone know what the problem is?
I tried, changing codecs, rebuilding graph etc, all didnt work.
Thanks again
Am getting the same thing with a Technotrend S-1200 USB. And have equally tried different aspect ratios. Its kind of opaq - you can see through the fuzzy, hazziness.
Any thoughts?
Edited by HenPen
Try to use another Codec and/or Overlay or Unchanged instead VMR.
I upgrade to a new NVIDIA driver (97.92) from laptopvideo2go and the line and fuzzy lower screen went away!
But I'm getting unwatchable jerkiness (aka frame drops?) and I realize I've got the dreaded Nvidia (GeForce Go 6150) -related problems and will post to http://www.DVBViewer.info/forum/index.php?...8&hl=nvidia "Best NVIDIA setup." I would really like to use DVBV so any thoughts after my post there is appreciated
-HenPen
