Player22 Posted February 24, 2007 Posted February 24, 2007 When I select Elecard MPEG2 Decoder with DVBViewer, I get audio but no picture and DVBViewer crashes forcing me to use CTRL+ALT+DELETE to kill the process support.zip Quote
Engelbert Posted February 25, 2007 Posted February 25, 2007 Try other decoders: At present this one recommends himself for PowerDVD 6 as a video decoder of Cyberlink (better still 7, Trial suffices), the Ac3Filter paints both than as Audio decoder: http://www.soft-ware.net/multimedia/audio/...licht=AC3Filter And under View| Filter| Adjusting AC3Filter like desired. Quote
SnoopyDog Posted February 26, 2007 Posted February 26, 2007 (edited) It would be interesting to know, which version of the Elecard (MainConcept) filter you are using. I have no problems with the Elecard codec with SDTV and the last HDTV MPEG 2 channel here on ASTRA. But i can see in your support file that you have Vista installed (DirectX version = 10.0, OS type = unknown) and Elecard has released their codecs for XP / DirectX 9 currenly. Edit: Uups - wrote in german Edited February 26, 2007 by SnoopyDog Quote
